Centerlink grinding on 440 oil pan
Final shimming to level engine, and no more oil pan rub on the center link. I measured my crank and pinion angles. I have very little difference, crank looking down 3.9 and pinion looking up 4.1. The rear has SS springs, lowering blocks and a sway bar. Fingers crossed.
This is what I am dealing with on passenger side. I could use 2 inches total, bottom of biscuit to pad. biscuit here measures 1.25, spacers are 1/2 inch.
It appears that by your instructions in a previous post, You have the mount mounted on the wrong side of the casting on the block, That will move it ahead so it’s sitting on the k frame pedestal better
It is correct per Schumacher instructions. It only looks offset in upside down picture. It sits square on the pad, engine is installed to correct dimensions for offset. I removed the homemade shims and used a Schumacher kit.
