stingerdart1972
Can someone get me to the link on the alternative master cylinder instead of going wth a power brake set up
Thank you
Thank you
Piston size is published at 33/32. Better start a squat program. Or perhaps you are a lot younger than am I.
The 15/16 (30/32) is much more user friendly for us seniors
Thank you
Can someone explain how these are better than a traditional master cylinder? Can it be used with vacuum assist?
I use a 7/8" bore MC from a "cloud car" (Status, Breeze, Cirrus w/ ABS) on all my Mopars- two power, one not. Need a 2 to 4 bolt adapter plate ($30 ebay).
Here's the M/C I've been recommending, and using for the last few years,, it 's 15/16 bore, for less pedal effort, and better feel..
It NEEDS NO ADAPTOR,, looks stock...
$50.00
http://www.ebay.com/itm/Brake-Maste...3ceed30135&clk_rvr_id=929799270667&rmvSB=true
