Logan
I'm cleaning up under hood wiring and plan to install GM HEI on my '71 Dart 318. I searched FABO and see where the "IGN" and "resistor bypass" wires connect together and power the system. "IGN" is hot while running and "bypass" is hot during starting. This scheme has the alternator field powered during starting and I wonder if this is a good idea. After all, Chrysler seemed to go to great lengths designing an ignition switch to avoid this. Since the voltage drops during starting, it looks like the VR will ask for max alternator output while cranking. I was thinking of arranging two relays as shown to correct the situation. Comments?
