an fitting and an6 hose?
taco502001
i am looking at relocating my holley fuel pump b/c previous owner thought it was puller not pusher. i am looking at 2 an6/npt 3/8 male fittings for the pump, 4 tube sleeves and nuts. just wondering what you guys think of using braided stainless hose and what fittings i will all need.
More costly but user friendly.
EASY! I used 8an for mine. What kind of HP do you make? You may want to consider using 8an with 3\8" fitting instead af 6an if you're 400+ (my .02)
8an is actuallt closer to 1/2" 6an would be 3". Fuel systems are one place were it wont hurt to go over board.
well yeah i could do 3/8 to 1/2 adapter as far as power its a built 440 so if it must be -8 an thats fine. just trying to keep everything uniform and fittings on my pump are 3/8 npt
