1967 'cuda
Dropped on Head as a Baby
Every day , I work on
The wonderful life of being a hobbyist gearhead.....
There sure isn't much about this work that I would call 'professional'.
Just beat the crap out of it and enjoy it!!!!!!:burnout:
If this is the son that gave you the welder for Christmas, I think you should go for the dry sump or whatever else he might want for the car! You probably know more than I about dry sumps, and it seems that most people praise them if they have one. Expensive and probably overkill for a street car, but the coolness factor should would increase.
On another subject I know you have experience in is painting the underneath of your car. I wanted to freshen up the underneath of my cuda that has still has factory undercoating on it. The undercoating from age looks a little gray and dingy, but otherwise in great shape. The car is an Arizona/New Mexico car so no rust. Anyway I was considering just brushing on some black paint over the undercoating using your method - laying on carboard and wishing I was about 20 years younger. Any thoughts on this project?
I know what a dry sump oiling system is. I just didn't know enough about them to be able to say much more than that I know what they are.
My son is in love with automotive things that look high tech. If flux capacitors were real, he'd want one.
(OK, O'Reilly Auto Parts does sell them)
http://www.oreillyauto.com/site/c/detail/EB00/121G.oap
Back to the Future..- I meant to say, back to the dry sump systems. I understand there are a number of benefits from a dry sump. It will do more than look cool and empty your pocketbook.
1)Because the oil no longer needs to be stored in the oil pan, - pans are shallower and you can gain ground clearance or drop an engine farther down towards the ground to aid in weight distribution or aerodynamics.
2)A larger oil capacity is possible with an external reservoir. That means that oil temperatures can be reduced especially if an oil cooler is incorporated with the system.
3)I have read some claims that the majority of the oil in an engine is actually in the top end of a motor when it's at high RPM. They say that under certain conditions the oil pan comes close to being empty. It's hard for me to accept this as true but who am I to question the big brains? It must be true. The fact that a significantly larger oil capacity is available would ensure you'd never run dry. - And because it's stored externally and constantly pulled from the pan, - your level would never get too high in the crankcase.
4)A multi-stage pump will not only suck oil from the engine but also air. That means it will act as a vacuum pump to give you negative crankcase pressure.
The benefit of that is more than I'd realized. I'd heard that a windage tray could prevent 15 HP from being sucked from an engine by reducing the amount of drag from splashed oil on a crankshaft. There are some sources out there that claim much bigger gains can be made with a good oiling system.
They say that when pressure builds inside the crankcase oil begins to act funny. Instead of just being flung from the crank, it will tend to ball up and adhere to it as it rotates. Apparently enough will stick that it increases the spinning weight of the crank. - So it's not just a drag from oil splashing onto the crank, but it's that, - combined with oil that wants to stick to it.
I've also read that the internal pressure robs power by increasing the amount of force necessary to push a piston down a cylinder during combustion. Some racers are able to use lower tension piston rings in engines that have negative crankcase pressure. They say the lower tension rings reduce drag and they see an increase of 20 to 40 more HP.
Whether or not low tension rings are used, they say that rings seat better with a vacuum inside the crankcase.
LMAO.... As a old geezer parts guy, we would call the newbie hired ( no experience, mind you..), ank ask for a flux capacitor for a Delorean. Another was piston rings, for a early 80's RX-7 /a radiator, for an air cooled Volkswagen. Gotta teach them, somehow....
I know what you mean about the cold weather, I had to think about wearing a sweatshirt last night for a walk in the neighborhood with the wife. Sorry about that, you can get back at me next July when it is 120 in my garage!
Lol,oh the joys of nature! Shovelled for 3 hours and then another hour on the snowblower a few days ago. Opened the door and there was a foot of new snow...
It's gotta be miserable up there! I'm never quite sure what expression to use when conversing with you foreigners north of the border.
CRIKEY! - sounds too Australian.
BLIMEY! - sounds too British.
HOLY CRAP! - sounds too American.
If only there wasn't such a language barrier....
I'll have to brush up on my Canadian. Looks like I'll have to re-watch episodes of CORNER GAS and Dudley Do-Right.
LMFAO!!!!!!!!!!! Just be sure to drink strong beer and say "EH" a lot!!
When I opened the door and saw the snow ...Well I can't repeat it on this family oriented forum:violent1:. But it had to be done. If not it all melts and then freezes overnight. You have an instant no effort hockey rink!
Corner gas is a hoot! Brent Butt actually recently did a Corner Gas movie. It was only in theatres for 3 days. I gues he felt CG is a cult thing...But that meant it hit the TV quick,and I was able to watch/record it. If anything it was funnier than the show.Interestingly,the entire movie was financed by donation.
Brent Butt is a genius. He is actually good friends with my wifes older brother. They play poker on the weekends. Maybe one day I'll get to shake his hand. Im a fan...
phtooooie!! ...
