pntastar69
Has anyone used Ansen's small block valve covers on their iron headed LA? If so, any leaks? What gaskets did you use?
Thanks,
Thanks,
They are cast aluminum correct? If they are flat they shouldn't leak.Has anyone used Ansen's small block valve covers on their iron headed LA? If so, any leaks? What gaskets did you use?
Thanks,
Funny story - I was removing the intake from a 340, and couldn't get it to budge. I went so far as to hook my cherry picker to it and all that did was pick the front end of the car up on the suspension.Make sure the upper edges of the covers are not interferring with the intake
