pishta
I know I'm right....
40-45? On a slant....273-4 was 28-33Yeah I know all that part, but what dwell spec am I aiming for total? I assumed the same total as the single points, but chit if I know.
With the 6's 60 degree lobes compares to the 8's 45 degree of seperation, you dont need a dual point on a 6 as the dwell time is already huge. Unless your after that nostalgia look. you could just defeat the 2nd set of points and still run 45 degrees dwell or like you said run them very small to reduce any point bounce at 9000 RPM and have them extend it to 40-45 spec.
