DionR
I have a project I am working on where I want to replicate the outputs of a new style switch but using an old switch. The new switch has a MUX setup where the resistance is varied based on switch position and uses 2 wires total while the old switch has different circuits for each position.
The ohms of resistances for the new switch I measured are as follows:
Off - 16.93K
Pos1 (Park) - 16.02K
Pos2 (On) - 15.55K
This is for a headlight switch out of a late model Charger. The old switch would be standard A-Body headlight switch.
Note that there is an additional complexity in that the Charger switch has a position for off that completes the circuit, rather than using an open circuit to indicate off. And just to be clear, this switch is only powered when the key is on.
Any ideas on how to wire up something like this? Maybe a circuit board or something?
Anyone have some knowledge about doing this kind of thing that they would share?
Thanks
Off - 16.93K
Pos2 (On) - 15.55K
Thanks
