Any one running Howards Cams?
Slantsix64
SSG
Camshaft, Mechanical Flat Tappet, Advertised Duration 256/256, Lift .473/.473
Any ever run this cam? want it with my 64 dodge dart 225 4 speed (3.09) 3.55 gears street car. Trying to balance power and economy
I ran this cam on a 4 speed and it was a blast! Sold the setup to a dude I California who is more than likely enjoying it as well.
Jake
Still debating on the Howard's cam 256 duration 220 @.50 473 lift 110
Or
the isky 152116 264 duration camshaft 228 @ .50 448 lift 109
Howard's operating range is 1800-5600
isky is 2500-6000
Howard's will help me keep that low end while the isky looks to be a mid range camshaft.
It's been said that valve lash will take some duration off the advertised, perhaps as much as 10 or more degrees, but it varies with the lashing.
So It could be possible for the smaller Howards to be a NET of 248*; And the Isky to be a Net of 252*..It would depend on the actual lash. So they could be just 4 degrees apart at advertised.
But it could go the other way too; say the Howards at 244* and the Isky at 256*. Now 12* apart.
But it gets worse The advertised does not come with a qualifier such as measured at .006, or .008 or .022; So there is just no telling what you are gonna get until you fingerprint them.
So, IMO, looking at the advertised, only someone who has installed one and measured it, can say with authority, what the NET advertised worked out to.
And that just leaves the .050s to work off. In this respect these two cams are just 8* apart, or about 1 cam size. Oh and 1* in the Lsa
But now look at the lifts. This reveals a lot about the lobes shape. The Howards is .473, and the Isky is .448. I suppose it's possible to put the same rates of acceleration on both lobes. But I suspect the Howards might whack it open faster, such that by .200 it is open further than the Isky, and maybe by .300 still open further. But sooner or later the Howards will have to slow down so as not to fly off when it goes over the top.
On the other hand, the Isky might open faster and then maintain the rate with a gentle over the top, but averaging more open dwell time.
Who knows; not me.
But here's the thing; You have a stated Scr of 9.5 and you have a really long 4.125 stroke, so you are gonna have to be careful to avoid detonation. Sometimes less is more. In this case the earlier intake closing point of the smaller Howards (assuming they are both advertised from the same reference point, and the lash spec is the same), the smaller Howards could NET a larger Scr, and BAM!! put you into detonation..... or require a higher grade of fuel.
So with that in mind,
the Howards in at +4* for a 106-ICL gets an ICA of 54*, which after lashing might be 5* less, just guessing, and so we get this
Static compression ratio of 9.5:1.
Effective stroke is 3.60 inches.
Your dynamic compression ratio is 8.42:1 .
Your dynamic cranking pressure is 172.68 PSI.
V/P (Volume to Pressure Index) is 102 .
And the Isky; in at +4 for 105-ICL, and an ICA of 57*, again shrunk 5*, to 52*now
Effective stroke is 3.53 inches.
Your dynamic compression ratio is 8.27:1 .
Your dynamic cranking pressure is 168.64 PSI.
V/P (Volume to Pressure Index) is 97 .
Ok so the first observation is the excessive cylinder pressures.
I don't know anything about 225 slantys but I'm pretty sure you can't get gas with a high enough octane rating to suppress detonation at these pressures.
But let's say for a sec that you could; notice the Howards is making 102VP versus the 97 of the Isky. That works out to plus 5%, and that's a lot, and gives an indication of its ability to perform at low rpm say below 3000, which with a manual trans IMO is almost extremely important.For you with a 3.09 low and 3.55s, this will not be an issue. But when you hit 1.92 second gear it will be. And with 27 inch tires 30mph will be ~2500 in second, so your slanty is gonna need some grunt down there. Yes you could downshift into 3.09 low, but now that split is working against you as the Rs jump up to ~4100 .
Ok so now, understanding the 1-2 split issue, you gotta pay attention to the lower rpm power production, and the Howards seems to get that done slightly better, if you don't downshift
But the Isky being 8 degrees larger at .050 will make peak-power about 200 rpm later... so now the downshift sounds pretty good....But that will not help it at 2500 in second.
But the big thing is gonna be the cylinder pressure. These are both single pattern cams so you can't move them around too far from the camcard spec. You could retard the Isky to match the ICA of the Howards or vice versa, so that's kindof a wash. The overlaps math out to 36 on the Howards, so it's not fussy about a header . The Isky maths out to 46*, so .... BUT again these are solids so the actual nets might be 26 and 36, so that kindof puts the Isky on the fence about wanting a header. Kindof.
Without knowing more about the durations in the mid lifts, I,personally, at this point, would lean towards the Howards if the 3.55s gotta stay, and also if no header, and also if the 2bbl is staying. Cuz that little wiener 2bbl is gonna be a choke anyway.
But you gotta do something about the excessive pressure.
Here is your Howards retarded to 108ICL and an ICA of 56*, shrunk to 51* for lash, with the Scr reduced;
Static compression ratio of 9.0:1.
Effective stroke is 3.56 inches.
Your dynamic compression ratio is 7.90:1 .
Your dynamic cranking pressure is 158.75 PSI.
V/P (Volume to Pressure Index) is 92 .
This would seem to me to be about max-pressure for pumpgas. Your lightweight 64Dart, and small carb might be OK with this. The slightly retarded cam might put your power peak up a few rpm, hard to say for me.
Ima guessing you shaved the head, so you are gonna have to measure things like; coilbind, retainer interference, and particularly, valve to piston clearance.
OK one more. Here is the Isky reset to a 108ICL for an ICA of 60*, shrunk to 55* and the compression lowered .
Static compression ratio of 9.2:1.
Effective stroke is 3.46 inches.
Your dynamic compression ratio is 7.88:1 .
Your dynamic cranking pressure is 158.21 PSI.
V/P (Volume to Pressure Index) is 89 .
I like it , but 158psi is still pretty high I really like this install. That 228* cam with the later install, should be good for something like 10 or 12 horsepower even with no header. With as you can see, very little loss in VP. That 2-1 downshift at 30mph should now boogie up to 37/40 or so mph and then the Rs would drop to 3130@37 to 3400@40 yeah I'm liking that. At these rpms that VP thing has shrunk to being almost meaningless.
So now the issue boils down to reducing your compression,lol.
What's gonna be easier 9.2 or 9.0..
Ima thinking that 9.1 and the Isky is your safest bet. Then you cam move the ICA around some for fine-tuning the combo.
Now keep in mind that I know nothing about 225 slantys and nothing about those cams. Guys feel free to.... kick .... my .... azz .... lol
Who knows; not me.
I guess after re checking my measurements my compression ratio will be 9 to 1 on the dot
Part Number/Work Order Number F21129
Engine Application SLANT 6CYL.
Grind Number 1/4 Race Cam
ADVERTISED CAMSHAFT SPECIFICATIONS:
INTAKE: Duration: 240º Lift: .449 Clearance Hot: .020
EXHAUST: Duration: 244º Lift: .449 Clearance Hot: .022
The specifications listed above are based on a rocker arm ratio of 1.50 IN/1.50
Timing Events
The information below is for degreeing cam only. Correct only at .050" tappet lift.
INTAKE; Opens: -2.0 ATDC/Closes: 30.0 ABDC
EXHAUST; Opens: 40.0 BBDC/Closes: -8.0 BTDC
LOBE SEPARATION 110º
Duration at .050" :Intake: 208º/Exhaust: 212º
LOBE LIFT; Intake: .299/Exhaust: .299
4 degrees of advance have been ground into this Camshaft.
If using "Lobe Center" method of degreeing, cam should be installed on an intake centerline of: 106º
NOTES:
___________________________________________________________
Nice cam; but I wonder if it will work in a 9/1 engine. Using their advertised numbers I get an ICA of 46* which I arbitrarily shrunk to 41 for lash allowance, and the Wallace says;
Effective stroke is 3.76 inches.
Your dynamic compression ratio is 8.29:1 .
Your dynamic cranking pressure is 169.18 PSI.
V/P (Volume to Pressure Index) is 104
Timing Events
NOTES:
It works great, This engine has head milled as to get 9-1 compression also here in So Cal we can only get 91 octane fuel. So with that info the set up is 11 degrees initial and 30 total with, vac set at 3 turns CCW from stop and engine speed of 2,500 rpm for 50 miles a day commuting I am pulling about 21-23 miles per a gallon. This number would be higher if it was only freeway miles and no hills, but since I live in a mega hilly area it is what it is. Almost like every stop light is at the bottom of every hill. This same grind is going into a 100% rebuild with some head work. But since I work for Crower I have access to a lot of machines not open to everyone. The one problem with this wallace computer/calculator is it does not account for ramp rates or area under the curve. The two cams above "along with many others" I put them on our cam doctor and started do all the necessary derivatives for , Velocity, acceleration and finally jerk. What I was trying to get was massive area under the curve with out the massive cam BS for a daily driver. In other words take advantage of the 0.904" lifter. Without making this way to long I can say that F21129 has 1% more area under the curve than the Howards and 3% less than the Isky. I was trying to make a cam that was a tweener ha ha ha ha. Anyways yes it is a great cam with great real world driving, and a mountain of data to back it up.
That's a great answer, awesome even.
But how does your combo deal with the pressure? I see your power timing is 30*. Is that at 2500rpm?
And since I have very little experience with HO slantys,is that the secret to keep it out of detonation?
Or is there another buncha degrees hiding in the before advertised numbers that is "bleeding off the pressure".
Or some other secret recipe. Like is the 240 spec after lash adjustment is taken up, and therefore equal to a zero-lash hydraulic. Even then the 5 more ICA degrees only makes about 5 psi less on the Wallace. And so at 400ft still pumping 164psi.
I'm asking cuz I have a 9.5 Scr 225 with a "bit of a cam " in it, (Specs are lost),and it is gutless no matter what timing I throw at it. I have had it since 1994. I have changed the cam-timing several times in the chase. I must admit tho that I built her for fuel economy and it has hiway gears in it . It does a little less mpgs than yours in a 1980 Volare with an A999 in it. I put Super Six manifolds on it, but that changed nothing.
Hey I just started it up on Monday, first time in three summers. A little splash of gas down the intake and Shazzam! Great engine, if a lil gutless,lol.
I dont want to high jack this thread so most of the answers you seek are linked here.
1969 Daily Driver
Ok gutless yes they are, after doing all this to the engine it is about the same as the wifes old 2005 Hyundia Elantra. In fact I believe the elantra would beat it in a drag race. Even before I changed the cam I could only get 30 total degrees of timing out of it with it sounding like a popcorn machine. The best thing I ever did was re-curve the distributor and limit the amount of advance. So it has 11 degrees and 19 in the distributor for a total of 30.
That is correct, Mopar used to recommend 32deg total & that is generally max even with sub 10:1 squeeze if it is running efficiently. Small bore+decent plug location+a decent swirl factor=not a lot of spark lead. If the hopelessly distant quench zone were closed into a squish, it can be less. I've seen iron-headed SBCs with WP heads that liked 25-26deg total with such a quick burn rate.
