[SOLD] ANYONE BUILDING A A518?
CFD244
"THE NEW OLDSMOBILES ARE IN EARLY THIS YEAR"
Northern Ontario, Canada
Hi Folks
I have a heavy duty 5 pinion steel planet set with annulus and sun shell from a 1997 A618 (RE47) from a Cummins truck. This set up is a direct install for 518's (RH46 & RE46) built from 1994 on (30 degree spline). A super heavy duty upgrade.
Looking for $250 USD shipped for the 5 pinion planetary.
Thanks FABO
EDIT: Just found out that the rear 4 pinion planetary from this transmission will also fit 46RH transmissions as well...........It has a double wide L & R reverse band and associated drum with off set apply lever. The intermediate shaft is there as well. Please inquire.
