I'm curious because I'm about to install the fourth one in my '68 barracuda and am kinda tired of it (to be fair, the first one in the car had sat for 10 years and was in bad shape). After I replaced the muck-filled master cylinder with a NAPA reman unit when I got the car in 2015, I drove it for a few months before the master cylinder would hang up and not release the brakes once the pedal was pressed. At the time, the local NAPA didn't have any more in stock so I went to O'reilly's to get one instead. The only issue I had with it was the fitting in the cylinder for the front brake circuit wasn't pressed in far enough, so I had to use some adapters to get the brake like to thread in. And now, my brake lines have finally rusted themselves from the inside, filling the whole brake system with rust particles.
I've given up trying to slap band-aids on my brake system and have finally decided to just replace everything in the car that comes into contact with brake fluid. I ordered stainless lines and new wheel cylinders, but I am hesitant to go back to NAPA for another master cylinder. Has anyone else had these issues with name brand parts store master cylinders? And if so, what are some good suggestions that aren't crazy expensive like Wilwood? (Keep in mind I'm on a highschooler budget)
