Anyone know what these fittings are called and where to buy them?
Rocket
U.S.A.
i am in need of two of these slide on fittings to finish up a carb linkage set up. These slide on a 1/4” diameter rod and attach to the carb at one end and the throttle lever at the other end. A set screw holds it in place along the rod and a wire clip holds it in on the other side. I prefer not to switch to heim ends at this time.
Any insight is appreciated
Do you mean one of these? I get them from a nut and bolt place that has auto hardware. Don't know what you are talking about set screw.
This is carb linkage stuff. This is not factory but is aftermarket/ "universal" stuff. I have not seen individual parts available. Good luck.
Try carb rebuilders. They may likely have large quantities of carb related hardware. One I know of is in Texas, goes by name/avatar "carmantx" on V8buick.com site.
Great recommmendation. I will order those Mr. Gasket parts.
