are a/c boxes and vents interchangeable
Elmer-FN-Fudd
Florida
are all those two peice a/c boxes interchangeable, i have a 69 ac box that i want to install in my 71 duster, not sure if it will work, also i dont know what kind of car the 69 box came out of. is there a way to determine that?
All I know is the fan diameter is different on heat only and ac/heat units. I'm guessing the biggest difference will be the cable controls but hopefully someone knows for sure.
thanks, i knew the fan was different, but as long as i can bolt in the box, i can make modifications for all the access holes and fan
