Sorry new member and this is probably a no-brainer question, But I searched but couldn't find it. I 'm replacing my worn out 7 1/4 with an 8 3/4 SBP 741 unit I just got that needs rebuilding. After looking at Green bearing conversion, I'm assuming that all 8 3/4 axles are all the same diameter at the seal & bearing area, since they only list one p/n for green bearing setup. Just seems to good to be true since everything else on these A-bodies is different/unique from all other bodies styles. I hope so because I have to locate all the 10 x 1 3/4 brake parts, since nothing came on 8 3/4 rear-end but the backing plates.
