Are factory 360 Magnum pistons coated
maca
australia
Hey guys I've been cleaning up some factory 5.9 magnum pistons with oven cleaner. I've done in the past without any problems but this time I left them a bit long. the oven cleaner discoloured the pistons a little bit. if they coated pistons then I'll replace them but if they're not coated I'll use them. Does anyone know cheers
none, coated are the ones with the black skirts....like these?
Several, but they are thermal barrier coatings, not like the break in coatings that piston manufacturers use. Usually you use a TBC on the crown to keep heat in the chamber.
I thought they had a skirt coating on them. But I wouldn't worry about it. Get some penetrating oil on the pins quick though.
I read that they are. Does that mean no coating?
Hypereutectic is the process used to cast the piston. It has nothing to do with coatings.
I have not seen evidence of the factory installed pistons having any coatings, but never say never.
Most aftermarket hypereutectic pistons have the skirts coated, like shown in pishta's picture. The Mopar crate engines and short blocks that were Magnum based and were larger than 4" bore did have coatings.
Yours can be run as is, as long as your piston to bore clearance is not excessive (probably fine), and you make sure the round holes inside the ring grooves are not plugged up with carbon. If they are plugged, just clear them out carefully with a fine pointed pick.
