Since getting the 4wd conversion on the road, it has wandered a bit, and gotten a bit worse. So a week or two back I rigged a video cam and monitor so I could watch the suspension as I wiggled the wheel. The axle mount for the track bar has some slop in the bolt. Not sure that is the ONLY problem, but it certainly is SOME of it. The bar is brand new Moog "problem solver" or whatever their heavy duty version is.
Yes, I'm aware that there is a LOT of torque on that bolt.
Below, test fitting a 1/8 thick shim that will go BEHIND the bar, and get welded along the outer edge. This hopefully will give the bolt more purchase as the factory bracket was only about 1/8" material. I had to grind the bushing on the bar to make it narrower to fit the pocket. It is a tight fit
Below, showing how the new pieces will fit. The small piece in the above photo goes BEHIND the bar as shown, and the right hand edge will get welded. The outer gusset is 1/4" thick and will get welded to the front of the bracket. This is a 14MM bolt which I shortened to make up for the added 1/4" thickness. There is not much room behind, a tabbed nut fits up inside the rear pocket,and you cannot even get a wrench, box or open, up in there.
Below, took an angle grinder and took 1/8 or nominal off the bushing width on the nearly new track bar to allow it back into the bracket with the new shim.
Below, old bolt. The bracket is a pocket, very constricted to "get in" there, and is only nominal 1/8" material. The bolt, 14mm, does show some wear
