B vs RB
RC Moser
Member
Florida
I've read about the difference and I think got good understanding, but I had 1966 belevdere 2 with g code commando 383 with 4 barrel carter carb. 1966 IMO was confusing year for 383. IMO the only way to tell would be verify the stroke. 3.338 B, and 3.75 RB. I also think any 383 before 66 would be B series. IMO any after 67 would be RB due to 440 come out in 66 and was created from the RB block. IMO all 383s after 67 were RBs, but I have found no way of knowing that. I do know all Road Runners and Super Bee engines were RB high preformance 383s with 3. 75 stokes. I do know all 361s 1966 (look just like 383s) were two barrel engines. Does that mean all two barrel 383s were actually 361?
I find it really confusing to tell 1966 383 was B or RB block without verification of the stroke?
Anybody else know any other differences, like castings on the block that would fornsure identify RB 383?
Nope. 383's were always B blocks. (along with 361's and 400"s) 413's, 426 wedge, and 440 were RB's (raised blocks) There are a few other B and RB engines built in the early 60's I didn't mention.
I guess tool man did state he isn't mentioning early 60's...so in a way we are both right, but I knew the 383 RB existed from years of writing vehicle application data.
68 thru 73? HP 383s were all RB due to the 3. 375 stroke. That's way I understand it. If it's got 3.375 stroke in 383 it was RB?
To quote allpar in the article I posted...
"The 383 cubic inch RB engine was only available in 1959-1960 on the US built Chrysler Windsor and Saratoga"
So it's rare you will ever even see a 383 rb and for sure dead by 1960
Little known fact a "chrysler 350" exists also in the B deck lol
The RB's stroke was 3.75"
And:
383
RB 383 "Golden Lion" engine in a 1959 Windsor
Not to be confused with the 383 B engine, the 383 RB had a 4 1⁄32-inch (102.4 mm) bore (with the long stroke of 3.75) for a displacement of 382.9 cubic inches (6,275 cc). It was only available in 1959 and 1960 on the US-built Chrysler Windsors and Saratogas; one of Trenton Engine's lines had been converted to the new RB engine (to make the 413), and demand for the 383 B engine was too high for the remaining line. The solution was to create a 383 RB to fill the gap until the plant figured out how to quickly switch from one block to the other.
Wow, was I confused. So all 383s after 61 were B engines? Thanks for the information. If I ever build my HS car (66 belvedere) I'll have correct information. For last question we're all 361s after 65 two barrel engines. Reason I ask is 361 and 383 look exactly the same for what I remember?
they look the same, simply look at the casting number on the side of the block. 361 and 383 have different numbers.
As a visual aid in determining the difference between a 361 and a 383 : there is a stamping next to the dizzy . On a 361, it will be stamped "361" or "36" followed by the date code . On a 383 , it will be stamped "383" or "38" followed by the date code . Also, following the stamped number there should be stamped a letter "R" or "P" . The "R" stands for regular fuel or 2 bbl. carb. while the "P" stands for premium fuel or 4bbl carb . ALMOST everything can be exchanged from a 361 to a 383 and visa-versa except the pistons .
Thanks 383S, that's exactly what I was looking to find out? Now I know. Thanks again from all that posted, now I straight on B vs RB and how to tell difference between 361 and 383.
