Hi All, I have a 69 Valiant with a 273. Engine is backfiring through the carb when I accelerate and looses power. I've replaced the accelerator pump, checked the spark plugs, wires, timing and also tried a new distributor. Just can't get rid of it. Any other ideas on what might cause this. Car was running great not too long ago. Thanks all for any help!
Is it a rhythmic steady pop? As in a cylinder firing up through the carburetor? If so, look for something keeping an exhaust valve closed. Wiped cam lobe, bad lifter, bent pushrod, bad rocker arm, valve stuck closed. Nothing good.
my pappy all way said "all ways check the easiest and cheapest things first." chrysler V8 can have #5 - #7 wires crossed easy. Mopar dist cap wiring... vent My dad made this saying about chrysler V8 small and big block dist cap wireing. To reduce wiring confuseion. “the small block has the dist in the wrong place, in the back of the engine. BUT the shaft rotates the right way clockwise. The big block has the dist in the right place, in the front of the engine BUT the shaft rotates the wrong direction counterclockwise. Both wire #5 and #7 on both ALL ways have #5 before #7 on the cap AND block. And most / some stock V8s have the fireing order cast in to the intake manifold. AND: DO plug the vent with JB-weld. Keeps the moursture out.
Your dad sounds wise, but I gotta disagree about stopping up the vent. Moisture is a by product of the spark inside the distributor. That vent allows it to remain dry.
With the exhaust valve not opening, she'll still pass a compression test. It will also not have a dead skip as that cylinder is still firing. It is simply exhausting up through the intake and through the carb......IF the exhaust valve remaining closed is the problem. Certainly though it will disrupt how the engine runs resulting in the poor power he describes.
I agree with RRR, if the timing is correct and plug wires are correct it just about has to be a valve issue.
Sure sounds like a timing issue, But if this is a high mileage engine, it could actually be some carbon dislodged that's floating around the chamber and holding a intake valve open? RRR hit on a lot of possibilities. I'll just add that the "chain" or the "balancer" being off could cause some issues also trying to dial it in.
X 2 on timing chain or cracked distributor cap. The OEM timing chain runs a nylon toothed cam gear. Known for shedding teeth and jumping. Replacement is straight forward but a PITA with the engine in the car. A cracked distributor cap can be hard to track down. Suggest starting engine in complete darkness. Look for visible blue-ish arc. If you see one, replace cap or wire, which ever is the source.
273 , damn good engine. To help diagnosis: How about telling us , what you actually have? And how , you actually, how you did, your parts replacement ? (This is absolute vital, for us to help you).
I think you tried all the obvious... take both valve covers off and look for a bent push rod and define which cylinder is the culprit. You could be doing valve or internal damage. For example... where is your wing nut for your air cleaner... it's happened. It or something could be stuck in the intake valve. Good luck...
This is probably the very first thing I would do, and then comp test that cylinder, and continue by pulling the valve cover for inspection. If it's not electrical, then it pretty much has to be a valve issue. It's hard for the average person to tell if it's an intake or exhaust valve but it could be either. (Could be a non opening exhaust valve or a burned/cracked intake valve) It's even harder to tell over the internet. (but it doesn't really matter which valve it is, does it?)
Hi All, Thanks for all the comments. So the things I have done to the engine: New timing chain (Sprocket is original), New timing cover, new fuel pump, new alternator, new carb, new distributor( tried a new one, still did it), spark plug wires had not been messed with before the problem started but are new, spark plugs are fairly new. I have checked all the easy stuff. I'll try and take a look at the valves this weekend. I just had hernia repair surgery so I'm kinda limited on what I can do right now. Thanks again for all the suggestions on what the problems might be.
What have you actually done for diagnosis? This is four days old now with basically zero evidence that you've done any of the suggestions. How about actually doing some diagnosis and reporting back? If we are going to take the time to help you, you can at least keep us in the loop.
Well I don't know if you've read my last post, I've had surgery and can't really do too much. I had posted to get some ideas on what I can check.
I sure wish you were local. I'd be glad to help. We gotta have a willing member in your area. I never can understand why more people won't speak up when it comes to help.
Tell you how you can instantly determine if it is an exhaust valve that's not opening. Remove the air cleaner. Start it up, drop it in drive with the parking brake set. Put your foot on the brake pedal good and tight. Ease into the gas and bring the RPM up to about 1500 loading the transmission in drive. If you get a steady rhythmic pop out of the carburetor that changes with engine RPM, you have an exhaust valve not opening and it is still firing on that cylinder, but blowing the exhaust back up through the intake and carburetor. At that point, you need to remove the valve covers and report back.
Check for bent push rods as was mentioned Check for major vacuum leak (extreme lean condition-carb or manifold) I'm leaning towards a stuck/bent valve or push rod.
Hi, all thanks for the great input. From all the things I'm hearing I'm leaning towards a stuck exhaust valve. Once I'm back to 100% and can get out there and check it out I'll report back and let you know what I find. Thanks!
Where are you located.. If your near me I would be glad to help a fellow member. I am in Johnstown,PA
