abqphilbert
Active Member
I'm out of my comfort zone here. I've built lots of European engines with multiple carb systems, mechanical and electronic injection, etc. None of that experience is helping me here. I'm building a 318 for a '67 Dart. 9.7:1 compression, .464 lift, 270 mechanical lifter cam, 318 heads with 1.88 intake vlvs. and 1.50 exhaust valves, nicely ported - not extreme. 4-speed overdrive with 3.23 sure-grip. 95% of my driving will be street, so I want the low and mid-range power.
Everything I'm reading says I should use a dual-plane manifold and (about) a 650 CFM carb for this application. OK, fine. Everyone local I've talked with about this says just the opposite - that the 650 CFM/dual-plane set-up won't have the punch I'm looking for, and tells me to go with a Torker and a 750 DP. Really?
That seems like too much for the kind of street performance I want. I don't want something that's gonna fall on its face until I get to 2500 to 3000 RPMs. I live at 5500 ft. elevation. Maybe that's why the local Mopar guys seem to have better luck with the Torkers and 750s.
Anybody out there have any thoughts on this?
Thanks.
Thanks.
