michiganpat
yeah, having the brake light circuit go through the turn signal switch is monumentally stupid. mine did the same thing with the replacement cams I bought, but everything has been working good with the full switch from Standard Motor Products (PN TW7)A buddy came over yesterday, and I asked him to check while I tried the turn signals and brake lights. The drivers side brake light doesn't work, but if you use the passenger side turn signal the drivers brake light works. So does that mean it is in the switch?
