Duster Drag Car
wondering how your Big Block Abodies handle with the factory front suspension mine is a 73 duster 440 with a modified k frame and motor mount someone cut the kframe for clearance and boxed it in by welding plates to the cut out area and welded 2 posts with a hole drilled through them for the motor mount bolts and i have a turn buckle on the drivers side from frame to motor for torque. the 440 actualy fit in nicely has no fenderwells but the roll cage extends to front frame rail but the hooker headers fit in nicely i thought the fabricator did a good job of meausering anyways besides 3 way drag shocks and drilled and slotted rotors the front suspension is factory. i did a little road testing and the car didnt handle well when acellerating it seemed to skate and pull, I am replacing the manual steering gear even after adjusting it, still had a lot of play front tires are skinny radials with bias ply slicks in rear that doent help this is a drag car so i know its not gonna handle like a sports car but i was just wondering how your big block abodies handle be it street or strip.
