Dart Sport 360
Wanna Race?
Hey,
We are thinking of building a stroker bottom end for our drag truck. Right now its a .060 over 440 with Indy SR heads, indy single plane and Pro Systems 1050. The cam is .690 lift.
We have a Mega Block with a window in the side.... I pushed a rod through it a while back and its damaged really low near pan flange. We have sent it to a place that welds blocks to see if it can be fixed.
We were thinking if it can be fixed we would buy a rotating assembly and then use the cam and heads we have now.
My questions is how big would you go? Its a drag race application in a 3800lb truck. 499, 511, 472 541, 572.....
Also would you suggest a kit? I was looking at the Ohio Crankshaft site and the eagle kits on JEGS. I know 440 source but I am not sure if the quality is on par with the others.
So there are pro/cons for each displacement.... Bigger may not be better. I'm curious what you think would work best with the cam and heads we have.
Thanks guys!
:burnout:
Thanks guys!
:burnout:
