AdamR
Big Member
My 69 Barracuda had the trunk extensions filled with expandable foam and the filled over that. The filler was 1/4" thick.
Could you suggest brand names of primer/sealer to use that are budget minded.
Sealer is not where you wanna use cheap stuff!
I use PPG DP90LF. Sprayable to bare metal. No need for acid wash/etch etc.. In 27 days you can't chip it with a hammer so do your bodywork/prep-work quickly thereafter.
You can use Shopline primers, sealers, basecoats, reducers through the process but use a Good Clearcoat. I prefer Concept 2021 which is a Excellent Mid-level Urethane.
The Shopline basecoats are a little transparent depending on which colors you choose. I just add a third coat for coverage.
As you can tell I like PPG but there are other good vendors you can choose from. www.autobodytoolmart.com sells some usable "Economy" products.
OOPS! This is "Bodywork" Thread, Sorry folks! You can also get some good bodywork materials from the site listed above too.
I have also used PPG along with their DP lines... back when DP WAS DP not DPLF. The lead free version is still good... just not like the DP. Coverage was a bit different. I tend to reduce it a bit also. I will be showing some use of DPLF tomorrow.
I too reduce it a bit so it will flow out. Its a really thick sealer! The old DP was ok but had adhesion issues at the end.
I tend to use the DPLF down first, then a decent filler primer, back to DPLF for sealer, Omni line basecoat with a PPG Clear. Never tried 2021... I have always used 2042 (sucks ***) or 2002... closest to the "old" 2001... a great clear.
I rarely do bodywork to bare metal outside of sheetmetal replacement. I never use "Bondo" due to its lack of adhesion. I prefer Evercoat 100416 metal glaze. I use a EagleII to remove all dents with no holes and for shrinking purposes. On the thicker sheetmetal the stud gun has to come out! I remove the entire dent and use a fine bodyfile to confirm low or high spots and continue until a smooth finish is aquired. Then apply the DPLF sealer. Once it has kicked then I apply a light coat of the glaze for a final sanding before the filler primer. Block down the filler primer with 600 wet and apply the DPLF before the basecoat color. Clear, Done.
4000 is probably the best clear PPG has imo. Just pricey!
2021 is a awesome overall! Crystal Clear and lays like glass!!
Hey would a 7" electric sander work for that instead of the air sander? I dont have a comressor big enough to handle that. I have one of these http://www.harborfreight.com/power-tools/sanders/7-inch-variable-speed-polisher-sander-92623.html
Oh and your PM box is full fyi.
I don't think I would use that. Thats more like a grinder/buffer. If your talking about prepping filler use a hand file like 67Dart440GT has in his pics. They are cheap and provide a flat smooth surface when used right. Nothing like a little elbow grease lol. I also found some nice aluminum sanding blocks at the local Hobby Shop that sells R/C Airplane kits. They work well too!
I personally use a Orbital Hutchins air file, best on the planet imo... When using pnuematic or electric grinding/sanding tools you must be aware that they cause a considerable amount of heat through friction that can cause warped sheetmetal. Use a slow speed until you are able to adjust speed with movement of the tool.
Is it straight line or orbital?
I ment for stripping to bare metal?
Great info. Thanks.
Keep it comin.
You mentioned doing a guide coat after sanding to find any highs and lows. What do you like to use? Will rattle can primer do the trick? It is easy to remove.
A handy rule on dents is "First in, Last out".
So when removing a dent you work from the outside towards the point of impact.
