Bonneville Landspeed Racing - Let's Try a Thing.
Live stream starts at noon CDT. They are moving all 3 race courses
Any reason why? Did they get rain?
I am guessing for safety reasons after yesterday's crash. It happened at 2.5mile and spread debris for a couple miles and likely dug up the surface.
I did see a video of people talking about a malfunction of the traction control on the pass prior. Just hearsay, but whomever was talking said they aborted early from the car being super loose.
My new vintage fire suit just got here. I love it, and it is white! Will be so much better than typical black in desert sun. Vintage Simpson SFI 3.2A-20
Photo attached
How did they do?
He had to make a licensing pass 125-150. He ran 138 but the engine wasn't pulling like he wanted. They worked on it all day, but I think he threw in the towel as he went there with twin turbos, had issues, converted to NA and had more issues. It is a tight budget and can't afford to hurt it, if it isn't already. I haven't heard from any of the crew today.
I just checked the triple valve springs that came with the heads.
Install height of 2.1
seat 219psi
open at 650 lift (current cam) 592psi
So, now we have:
Indy 440-1 ported with 2.25/1.81 valves
Indy 440-1 intake
Chet Herbert 260/270 @ 50 with 685 lift with the 1.7 Jesel rockers
Use this on 470" B motor, what compression? Does it make enough difference between 11.5:1 and 14:1 other than the requirement for good fuel? I am leaning towards the 11.5 so 93 octane will work for street and race gas for racing. This make sense? There will be overlap bleed off and racing will be at elevation. And what carb? I see some great results from using a 4500 carb and super sucker adapter to 4150. Sizing thoughts?
So, now we have:
Indy 440-1 intake
Pick the fuel first. That will dictate what class the car runs. Set the compression to match the fuel. I’d run as much compression as you can on whatever fuel you pick. How do they classify E85 for bonneville? Does that put you in a “fuel” class?
I believe I want to stay will gas. Alcohol would be nice for the cooling properties and tuning, but gas would make it easier with my overall goals with the car. E85 fits into a Fuel class.
If I run Time Only, then I can do whatever I wish, up to my safety equipment mph limit. IF running in my class, gas seems to be the right choice. Again, if not in impound, then not a super big deal.
The record for A C/GALT (2024 book) is 237
The record for A C/FALT (2024 book) is 264
So, if running gasoline, I see numbers of 4% change in HP per point of Compression, unless the cylinder pressure wasn't optimal due to cam profiles. It doesn't seem worth it to make it race fuel only for 50-75hp. Maybe it is.
I believe I want to stay will gas. Alcohol would be nice for the cooling properties and tuning, but gas would make it easier with my overall goals with the car. E85 fits into a Fuel class. If I run Time Only, then I can do whatever I wish, up to my safety equipment mph limit.
The percentage of gain from compression isn’t a direct correlation like some people like to make it out to be. On a 300hp small block Chevy yea you might see 3,4,5 percent as you go up in compression but at the 600-700hp level backing OFF on the compression, especially when you have the heads and camshaft to go with it, will really hurt power.
