Bracket Car Wiring Help
She’s back from paint. Hope to have the wiring done soon so I can install the engine and transmission and be on the track before long!
@70 Buster 340 did you have a chance to take a look?
I’ll PayPal a sixer of beer (at least the $ for one) to whoever can help me nail down this wiring diagram before I start this wiring job ha
Not yet ... but I did drool on my keyboard when I saw the picture of you beautiful Demon ... now it is dry and working again. LOL
I'll take a close look at the instruction sheets you posted .. tonight.. and see if I can help.
Thanks! It’s been a long time coming but it was worth it. Sorry about your keyboard ha.
Sounds great, much appreciated
Got the boxes mounted. Just need to mount the solenoid then I’ll be ready to run these wires. Think somewhere in this circle area would be suitable for the solenoid?
Ok. See if this is any closer to making sense. The purple (start) wire goes from the start button to the NSS, then out to the small s terminal on the solenoid. The shifter switch grounds when the shifter is in park or neutral to complete the circuit (if I understand correctly.) So purple wire at both poles of this switch which grounds when in those positions? Purple in and then out to solenoid?
That location on the firewall should work for the solenoid and it's proximity to starter. Consider how you will route the battery cable from the back, clearance to headers, and heat soak.
