73dartswngr
I have a 73 swinger with the stock attributes. it has power brakes that seem to not wont to work. I have replaced the front calipers (yes they are put on the correct side), did this because the bleeders were both shot and just thought that new is better anyway. the problem I have is that the peddle goes to the floor, either running or not, and with little effort. This was happening before the caliper change and has continued after. I do have a huffing noise that you can hear from the booster when the engine is off, just wondering if that is normal or not. any ideas would be great.:violent1:
