Brazilian Dodge Dart 76 (similar to 69 usa)
Does it have rum or any kind of booze in it?
The lemon drink that is.
BTW....I love your skills at taking un-obvious items and modifying them for your application....your car will be sweet when done no doubt.
That's using your noodle.....and yes please more pics of the hottie (I hope) with the pink thong.
Mop
Fat blue fish
I love your restored treat Alex
OgAAAKZON2ef7zvVLy1tF54n4eed3aydyLtuVJ6CualuGmVSzao2udfj8Vg7vdPCwKMmNvupum9N-HIDNGtJPztMNQUAm1T1UPu5dXlL5ZEYz9ZQlE4OSTQ1kFu_.jpg
and I love tooooo caipirinhas or RUM :-))))))))))))))))))))))))))))
as I was alone, I put rear axle upside down to make work easier...
Now I have move it to right side... tomorrow I hope..
I'm having some problems with my parking garage. My building manager came to me to say that I have to move my car tomorrow due a repair in parking garage floor...
BUT it was suposed to be on 15th august.. mother FFFFFF ...
Let's make another caipirinha!
I use 2 or 3 spoon of sugar (granulate) into a glass...
chop half lemon (just wash it) and knead it with sugar and 1/4 of glass with caxaça (ka tcha sa ) or vodka.. I prefer vodka..
.. you have a juice as result.. add some ice..
You may remove the lemon from glass...
now I chip the other half lemon ... use it as decoration (and while I drink, I knead it to)...
You may add more caxaça (or vodka) and water... try do mix some glasses... there is not a rule to make caipirinha..
MMMMMMMMMMMmm that looks refreshing.
SInce I love Vodka I will have to try one tonight.
Thanks for posting your drink build.
Mop
not the way I planned, but it is on wheels.
I instaled rear axle to push it to a friend parking garage (something about 3 or 4 squares away)...
note the new scratch... while I was pushing it out of my parking garage..
Not exactly a great ride...
first shot.. my friends (crazy like me)
second.. to move the dart front end... an old pallet with a junk freezer wheel base =P~
3rd. time to dream.. I was dreaming at driver side
4th. We have a problem! lost one wheel... floor was crap for 50meters..
5th to 7th shot.. solution to problem... we put a new engine onto A-body
last shot.. resting in new temporally parking garage.. thanks to all friends that helped me a lot
first time I use compressor
love it. I do have to learn a lot... but job is done
I painted K member and engine mounts.
As soon as I paint other front end suspension, I'll put all together..
K-member and engine mounts are black
all other parts are going to be dark gray.
Hi Alex,
Your car is very nice my friend!
I'm very happy, because my Dart is ok!
See a picture!
See you!
Main
backing home after parking garage new floor
[ame="http://www.youtube.com/watch?v=plFryZYA2YQ"]YouTube- dodge foderoso BH motor BB - big barriga[/ame]
last weekend I painted a frind's dodge dart. It is my second paintin job... about 2 or 3 problem (as drops in the paint).. but quiet nice to this place.
I built a frame to help me while I paint...
I used some scrap wood and some scrap nails also :D
I painted some parts from front suspension and I took another shot of K member
I started to reinforce low arms
I cutted a piece of sheet metal.. about 3mm thin (1/8 in)
a friend welded... now I will drill it.. I also have to grind weld to make a good painting job later.
almost finished
I started to grind weld but my disks finished
I use a cheap dremel clone ... I use standard cut disk, break them and make them small circles... finally they are fine to use in small eletric rotary tools.
but be carefull with these tools... they have a very hight rotation speed. I use the lowest as possible
grinded some parts..
front disk brakes rebuild kit
engine mounts and sway bar brackets and bushing
i
Where did you get those sway bar brackets?
Hi, brackets came from a ford escort first generation just as the one from this link...
http://en.wikipedia.org/wiki/Ford_Escort_(North_America)#First_generation_.281981.E2.80.931990.29
Brackets and bushing fits quiet well dodge dart. I've made I minor modification.. I prefer to use screws in metric unit.. than I remade the hole to a 8mm screw.
If the distance of the holes is larger than the distance from the dodge plate, you can put the brackts into a vise and push it..
hope you understand.. make contact if necessary
