Brodix B1 BA MC Heads
Well what did you do did you go with a B1 heads
In my opinion the only problem with the B1 is modifying though headers to fit correctly
Well I went with w9 head's , I got a set off brett miller. I think it's my best option write know. I have to modify my exhaust no matter what way I go.
May I ask why you needed to go with an 18 bolt head?
I know you’re gonna run boost, what head gasket are you going to run?
Best of luck on your build!
Best of luck on your build![/QUOT. Because it's the way to go. I ran 20 psi with my indy head's before I hert it and had no problems . It made around 1000 hp. I want to go higher and with 18 bolts and mls gaskets it should be no problem.i hoping for 1300 out of this new combo.
What type of boost ? { Turbo, Procharger, Roots } Good Luck and please post results.
Not sure what happened . I'll try again. If you have the option , it's better . I've been running mls gaskets and they work pretty good. With my old motor I was running 20 psi with no gasket problems.
Yeah buddy, that’s a lot of boost!!!
May I ask why you didn’t O-Ring a 10 bolt head? pic for reference
That won't help you. The heads will still lift with 10 bolts. . That's why the racing block is 18 bolt . But yes my other motor is 18 bolt as well and it will be o ringed . That motor will see 35 psi. If your using a stock block your looking for trouble. I wouldn't go past 700 hp. I'm looking for a lot more. My w8 motor should be 1800 or more.
