Broken Transmission
macman340
Little River, SC
After pulling the transmission out, the converter now has crankshaft bolt mashed into it! It is an aftermarket converter! Any thoughts on the cause!
I've had crank bolts leave impressions through paint on the converter but no dents in the converter unless I had a major driveline breakage. Clearance is tight. However, that doesn't look like an OEM crank bolt and they definitely don't come with washers.
Yes, those bolt heads are definitely too thick. I would also be concerned that it had affected the end play of the transmission input and very probably taking out the front pump.
Good point! No doubt this is part of the reason the transmission had to be removed, but what was the transmission doing (or more likely no longer doing!) that necessitated it's removal?
Ok, Ok, sorry everyone, the transmission is a 904 , 1968, the flex plate is a B&M SFI Steel, I just got it out yesterday , the reason for pulling it out was a grinding when put in gear, here is what we found upon 1st inspection the output shaft was sheared off photo 1, this happened while (Ibelieve) while doing a burnout and the tire bit the track! Didn’t mean to cause a fuss, pittsburgracer
Yea, something violent happened, too say the least! I'll assume when it did this it shoved everything forward , explaining the flex-plate marks!
Like I suggested earlier I would put a dial indicator on your harmonic balancer and check forward and backward motion of your crank shaft. Should probably remove the belts first.
The low one way clutch probably broke if you were still in first when the tires got traction. When the other parts broke it could have pushed the TC into the back of the crank?
If your valve body is a full manual and does not have low band apply the rear one way roller is the only thing holding in low gear. I would suggest getting the VB that has low band apply.
This car was mistreated in 1st gear causing the sprag to roll. It appears the case is also broken, and if not, it will likely need another case anyway as once that inner sprag race is removed you'll probably find it dug into the back of the case as well. Not to mention what you have going on up front with the crank bolt witness marks on the converter. Probably some ballooning as was mentioned, and probably wiped the thrust bearing in the motor, as was mentioned. This is going to be a costly one as that transmission is a complete goner, (lots of hard part damage I'm also betting) and you'll need to find a useable core--not to mention any engine damage.
Quite fortunate the doggone thing did not blow up and cause bodily injury. If people realized how fast that assembly is moving when the sprag fails they would never, ever do that. At 5000 rpm with 2.45 first gear the drum could spin to 12250 rpm!
