zac_F71
I will be going with a off the self Comp cam kit as it comes with a timing chain which I also need - don't need springs as I have some on another pair of heads
"That's nearly a stock cam. " Yup. And it works well, and wont fall flat on its face when you mash the go pedal. A 292 is alot cooler when talkin with your buds, though.
292 cam. No, its not a big cam but it wont need a lot of upgrades to go with it either. I have ridden in a stock 383 rebuild with Cranes blueprint cam, it ran strong. This is 2 steps up from that cam, albeit small steps for Crane. I thought it was a good choice given what he is looking for.
Had a completely stock 1965 383 with stock 516 heads, mopar 528 solid cam (242@.050, .528 lift, 112LSA) , Holley street dominator intake with 850 holley and a set of 1 3/4 headers that went 12.65 in a 3500 lb coronet. That motor was lucky to be 8.5:1 compression, the pistons were .045 in the hole with who knows how many original miles. It was also the toughest low maintinence motor ive ever seen. If i were you id copy what i did. Especially if your on a budget. Oh and get a 4000 converter, that will really wake it up
^^thats gonna be a bad *** ride!
Well due to budget constraints I've been crunching numbers - got about $2,700 for the motor/trans/ exhaust/fuel system
parts -
Hedman headers
Summit 2.5" X pipe
Dynomax Ultraflow's dumped
I priced the Summit X pipe, reducers, 2 Dynomax's, and a 45* bend to make dumps for $320.. thanks though.. I can't run tail pipes cause of offset hangers/shackles in back..
Ok guys got my tax return and loan so money is getting spent here-
440source aluminum heads (confirmed with Kim the below cam will work with the included springs)
440source aluminum underdrive crank pulley
Comp 280 / .480" cam
Edelbrock Performer RPM w/ 1/2" spacer
Holley 750
Hedman B body headers
3500rpm hughes stall converter from a fellow member
everything else will be left til money allows -
