12valve
Scamper, If you want that crate motor have it shipped to me and you can drive down and pick it up. I'm about 45 minutes from the border.
Jason
Jason
ECHO, echo, echo
True. I do not have a stock engine around anymore to measure. Do you have a compression calculator on hand? Run the numbers with a 360 head @ 72 cc and a then again @ 65 for a typical Edel. head and again @ 55 for the W2. The head itself is available, just not assembled. (Another damn shame along with the W5 disappearing.)
I had dished pistons in my anchor so I swapped the pistons... everything else is stock in the bottom end. I just went to a flat top with a zero deck height and I'm right around 10:1....
You mean a flat top with valve reliefs. You caint run a true flat top at zero deck.
Sorry, yes your right.... the point being, the stock dished pistons were more useful as ash trays....
Heads = Power for sure! At the time I didn't go with alum heads because I wanted the car to look stock... I knew it would be slow (12's) and I didn't want to be at the crappy tire cruise and people seeing alum heads and thinking it was really built up.
I don't know if the X heads that were posted above were around back when I got mine but that looks like a good way to go now for the money... need everything else but its a good start...
Oh yeah, one thing you guys in the USA might not know... Here in Canada, we get raped on parts... totally raped, no lube, not even a reach around... I collected parts from ebay and brought parts back from the states when I could. Very little parts on my POS were purchased thru Canadian Speed Shops. You guys down there have it better then you'll ever know.
No passport so that leaves me local. So stock bottom end,do I need all the machining or just an overbore. The reason I ask is half my budget will go into machining the block. I do at some point want to add a 100 shot of nos will the kb pistons work with this?
I wish on heads, I was going to get a set but they will eat up most of budget as it is I will have to wait and hope for a decent set of used to come along up here do to the border fees. I appreciate everyones advice so far.
