lil red
sireland, (sorry not trying to hijack the thread)was was the spec you ran for a camshaft in the 4x4..
Comp 20-613-9sireland, (sorry not trying to hijack the thread)was was the spec you ran for a camshaft in the 4x4..
He gave you a big block cam?
Oh sorry, the cam attachment said 3 bolt in which my head went right to big block.
What heads do you have for this?
Block is at machine shop almost done ending up going with a forged rods nd pistons with a internal balance so kinda seeing boost here soonAny news on the build?
You will love it. That's dam close to what mine is.
KB 107s above deck 12 thou. Squaring the deck took way more than planned so comp ratio went from 10 to almost 11
560 lift, 107 LSA.
big valves
Full internal ballance
Tunnel ram and twin 4160, 460 cfm.
4.88 rear and spool
29X10.5X15 DOT drag radials
100 percent "street" car.... runs all day on 91 pump swill. Transforms rubber into white smoke and fuel into smiles. (Unless your at the light next to me.)
My engine is going together here soon with the same goals.
360 .30 over
Speed pro flat tops and edelbrock heads
10:1
Hydraulic roller cam that is .522 lift
Performer rpm intake and 750 dp
Tti long tubes.
Dyno day should be in a couple weeks so I will try to remember to post my results on this thread for you.
That is awesome results. What car is it going in?Engine made 415 hp and 430 ft lbs of torque.
That is gonna be one baddass swinger!!! Is it in the car yet?73 swinger
Lots a folks said 10.8 static compression is to much for iron heads on pump 91 but I can tell you it's not.
When I go aluminum heads I'm gonna push pump gas even more. In fact I wanna push it right to the edge and maybe just a little bit past..
A lot also depends on the cam and timing as well as the quality of fuel. When asked about compression and fuel, I’d rather error on the side of caution for the reader for no problems in his build than grab a few tiny hp he will never notice. Proceed at your own risk.I ran my 10.6:1 5.9 magnum on 91 pump gas. Never had an issue and it ran GREAT. Had several people tell me it wouldn't work, but I did it anyways since those were the parts I had. I pulled it apart and didn't see any signs of detonation so it went back together with aluminum heads.
I thought the 4 cyl. were score dinner?!?!On the plate is, blue oval and bow ties, for dessert some dainty four cylinder snacks.
