74slnt6
I have 440 sources ( now discontinued ) pertronix Hei style distributor for my 440. I will be going to use the ignition box located on the distributor. for this to work, the dist has to have a 12 volt source. I plan on using the same wiring as the slant six, just to keep it simple. I still have all the wiring hooked up, I just need to bypass the ballast. It is a 4 prong style ballast for a 74. whats the best way to bypass the ballast? cut and spice? remove the ballast and just bridge the two old connectors? Sorry for the stupid questions, im not to familiar with any electrical yet.
