I would like to clear a few things, I respect Jim at Racer Browns. He had a number of ideas for the right cam profile for my car. I need to confirm the 340's actual compression ratio. Once I have that I going to contact him and go from there. I have researched this issue with the rear gear ratio/ tire diameter since I bought the car years ago. I am finally building the car, and the cam choice is tough since it not the most common application. I have gained a lot of information on FABO. I started this tread to find out if anyone else has experience with this problem and what worked for them. The more informative you gather the more you know. Which is why I contacted techs from different cam manufacturers. My goal is to know more so I can talk to Jim some what intelligently, at least I hope.
Not a bad idea. I would listen to Jim ultimately though. He is perhaps one of if not the best camshaft mind on the planet.
