Gtsjosh
Active Member
Looking at ordering a cam soon for my 69 dart gts with 340/ 4 speed. Engine is stock except for the usual bolt ons. Headers , dual exhaust , electronic ignition from fbo, avs2 650 carb, 391 gears. Tire are 245/60/15 next set I buy will be 255/60/15. Plan on doing the Edelbrock rpm dual plane intake same time as the cam.
Car is only driven on the street. No plans to rev it to the moon. Just a fun street car wanting a fast light to light and 0-80 majority of the time. Trying to avoid pulling the x heads and doing machine work for now. Plan on running it like this for a while. I will upgrade springs.
I’m out of the country for work so getting Recommendations has been a little tough. But so far
Howard’s recommended the street force 2
Hydraulic Flat Tappet Street Force 2 Camshaft & Lifter Kit; 1964 - 2003 Chrysler 273, 340, 360 1500 to 5000 Howards Cams CL710031-12 | Howards Cams
Hughes recommended
https://www.hughesengines.com/Index...RmxhdCBUYXBwZXQsIEh5ZHJhdWxpYw==&partid=30240
A lot of people are partial to the xe268 from comp cams but I have not called comp yet. Just seems like a popular choice.
last I’m very interested in this one but I haven’t got to talk to Lunati yet either. This seem to have good feedback though.
Voodoo Hydraulic Flat Tappet Cam - Chrysler 273-360 262/268
this is my first cam swap so I’m a bit ignorant on picking a cam to benefit my compression ratio and how isl lsa affects the engine. Thanks for any advice.
Hughes recommended
