AJ, the book says factory cr is 9:1 on an 88 roller 318, I know that is not exact but with the head cut I would assume its close. It does have almost 160psi wet/ 150-155 dry,cold on all 8 cyl with just a home hone and new rings. I installed the cam with the timing chain set to the 4deg advanced marks. it is 18deg of timing at 800rpm. 15in vac. I know its hard to figure out online but I do appreciate the helpful ideas/direction.
So I guess what you are saying is; the cam was never degreed in,and the cylinder pressure is between 150 to 155psi,and you have no idea what the true compression ratio is.
Well thats an honest start.
Now you are supplying more erroneous numbers.
-A 230* cam will not likely pull 15 inches of vacuum installed at 4* advance, or with 18* initial, or at 800rpm. Not likely. Id say you're having a tough time.
-Well,there is some good news. The high vacuum tells us a couple of things.Firstly, you probably dont have an intake leak. And secondly the initial timing is at least close.And thirdly the valves are closing, so the valve train is probably ok too, OR the gauge is not calibrated correctly..
-Now lets back up the bus.You have given several pieces of information that lead me to believe that your cam may not be as big as 230*,or it is not installed correctly, namely; the virgin deck height, the factory compression ratio,the cylinder pressure and the idle vacuum.However, for the moment lets ignore that stuff.It could be as simple as 2 bad gauges
-Lets try to get to the bottom of the idle issue. For an engine to run, it just needs 3 things;1)adequate compression, and 2)a correctly timed spark, and 3)a combustible fuel/air mixture. You have them all,cuz it idles at 800, in P/N.
-About the only reason I can think of for your stalling issue is; The carb went rich the moment the tranny went into gear. This would most likely be a powervalve issue.It could be other things as well. If the tranny is slamming into gear, the sudden drop in rpm could signal the powervalve. If the TC is faulty, same story.
-So lets check the TC first, cuz its easy.This is what I would do; Get the back wheels off the ground, rear end on safety stands. start er up,crank the idle down to 850ish,put it in drive,brakes off. Let it idle in drive,wheels turning. Slowly brake them to a stop.Will the engine keep running? If no, the TC is bad, or it dragged the rpm down too far, and its still bad.If yes,it stays running, lets go to the powervalve.
-So the first thing to do is to defeat the powervalve in the quest for a solution.
If you have a metering rod carb, this is easy, just pull the springs out from under the pistons.With a holley type carb, I remove the powervalve and swap in a plug.So after doing that,bring the idle back down to 850, and put it in Drive.
-So what happened?
If it stays running, you will need to recalibrate the powervalve.For the Mrod carb this requires softer springs. For the holley type, a new PV.
If it still quits,I'm outta ideas.
