- Joined
- Jun 2, 2004
- Messages
- 5,032
- Reaction score
- 41
Time to crack open the piggy bank marked Cuda Resurrection Fund and buy some stuff to make this lump drivable again. I'm ready to buy parts, including a cam. I'm running a MP short block that was advertised as a 9.5:1 compression version. I doubt if the CR is above that including the milled heads. The induction is a stock 6 Bbl, Crane 1.5 roller rockers, MSD pro-billet & 6AL, Hooker super comp's into 2.5" exhaust w/ 2 chamber Flowmasters. The car is a 4 spd. w/ 4.10 sure grip. I want it to run strong, but not be a tempermental little *****. I was considering the Comp Cams XE284H. Or do you think the XE274H is a better choice? I want that raspy idle with a good top end charge. Fuel mileage is of no concern since this will be a toy.
Fire away....
Fire away....
