YepFirst year impala- 1958?
Bel Air was top of the line until 57.First year impala- 1958?
Stock longblock 4 bbl headers xe262h 282hp @ 5000 rpmI've mentioned several times that I'd love to see the same kind of analysis I've seen with big block cam selection or even stroker/340/360 cam selection applied to a reasonably mild build 318, with no other mods but, say a 4 barrel and dual exhaust, and maybe starting with one of the 9.2:1 factory engines.
I know we have several in-house persons with those kinds of qualifications.
There are at least a dozen off the shelf cams that qualify as a "next step up" or "two steps up" cam from the .400 lift of the factory part, without getting into the "mill the valve guides" lift area. Maybe all those in the .450 lift and under.
If only I had lottery winnings to figure out what to do with.....
They said it was a jobber rebuild be low crDyno test of 262 cam from link comments-
Issue 1- They never actually said with the compression ratio was. Is it 9.2:1 (actually very likely real close to that) or 8.8:1 (likely less)?
I'd guess 20-30hp but would of been nice, probably didn't cause of time and or lazinessIssue 2- I sure would have liked to see what the dyno said about adding just the 4 barrel. That would have been more logical than dyno-ing "just the cam".
I can't believe those guys didn't think of that.
Would be nice if people did a little more testing with different mild 318 combos, this all we got that I know of.Issue 3- I wish they would have also done the "256" cam. Comp's "desktop dyno" shows a MUCH broader torque curve (they did note a broader curve), and only a 10 max HP reduction. That's a VERY logical trade off in a street motor build. It would have been worth it to see it on the dyno, vs "on paper".
But really even with mild engines at full throttle do you spend much time under 3000 kIssue 5- Why TF didn't they continue the low RPM readings at 2K? this is a mild build, we want to know (especially if it drops). Street driving doesn't start at 3K.
What would that be? their basically throwing an engine in their buddies truck but used the opportunity to give us a basic Idea what such mods could do.I knew they couldn't resist throwing on something they "just had laying around". Every single one of these write-ups does, usually to the tune of a major effect on the outcome, and potentially adding hundreds of dollars to the "low buck" status for a reader to cough up while also skewing the results away from the intended point of the test.
Problem is most people doing a 318 is that generally it's what's in the car and running and just want to add 4bbl and mild cam , not rebuild for cr not install gears or stall, probably looking to burn a little rubber. 318willrun's 318 didn't do to bad with these basic mods. What may be a dog to you might be fine to others.Did I mention that my 2012 Orlando has a 2.5liter-6 speed advertised at 167 RWHP? 2.5 liters is 152.5 cubes that'd be close to 200 crank HP. Did I mention it pumps 220 psi on the compression tester?
This engine has a VVT system that switches at about 4500 rpm. The only time I might use it is during a misjudged passing maneuver. The car is advertised at over 3600 pounds.
For a 318 streeter, it's all about the pressure, ............ unless you like a 3000 stall convertor..........
But if you have a clutch, then your engine is nearly married to the tires, so if the rpm comes down too far, you gotta downshift or that same engine better have some pressure.
The 73 up low-compression 318s seldom pump over 135 psi, which is disgustingly low.
I had one in my Barracuda that was my winter engine.
It came out of a 75Dart, in the which it wore the 340 top-end and cam, no headers but dual exhaust. ran a TFII A904, factory stall, and 3.23s. It was a complete and utter dog............ except it had a pretty good passing gear; 60=3800 in Second gear. The car got to be too rusty to be seen in public, so;
I took that engine out, put it back to stock, and dropped it into my Barracuda for the winter, with 2.76s, that same TF-II/904 and a 2800stall. But it now wore the TTI headers and dual 3" full-length exhaust.
What a difference! Nicest 318 I ever had. Still only 135psi.
I liked it so much that in 6 winters I never touched it. I did however every winter run a different trans and gears.
One winter she ran 4.30s with a double overdrive manual trans. 65=1930rpm. I used the GVod as a splitter, and what a hoot that was. Seven useable gears with pretty tight ratios. Ka-blam! What a combo!
The Roadgears were; 13.29-10.36-7.18-5.60-4.30-3.35-2.38 with splits of
.78-.69-.78-.77-.78-.71od..... a gear for every occasion, and another one close by.
The chevelle should've been faster than that. Maybe he didn't know how to tune his combo. My stock 74 duster with a /6 ran low 17's. Depends on what else was done, that 850 could've been to much carburetor, I've seen it beforeMy uncle Wesley had a modded Chevy six back in the day, and my friends wife has one in a 50 Impala with aftermarket intake. That being said, another friend had a 69? Chevelle, 396, 4 speed, 850 cfm Holley, ran 18's in the quarter. You just don't know...
Chevy 235 which was in the vette, I find it hard to believe that gm would back down from the mopar 170 slant 6. The/6's can't be spun very tight due to their long stroke/ long rod design and the crankshaft only being supported by 4 main bearingsI built a 170 for the 64 Barracuda in the 70's when gas was too poor to run the 273. I was inspired by the "Baby Grand Nationals?" where the Mopar 170s came in first for as many as were entered. They never ran again since Chevy and Ford could not compete. A real sweet motor, not stock.
Wow, that's awesomeYou need more experience and less theoretical BS and marketing. There was a 170 cu in limit and I was talking about historical fact, the other manufacturers were not even close. All /6 use the same bore, only the rods and cranks change until the smog era. A 170 has the shortest stroke and a shorter deck, and will rev the best of the /6's. Also being the smallest cu in using the same head will naturally rev higher. The 170 I put together would easily beat a Chevy 235 straight six in anything an engine does for next to no money.
I had 3 /6's, I wasn't impressed by the acceleration of any of them, actually all of them were dogs. I didn't have a lot of money to invest in them and I pretty much thought that it would be a waste of time and money. I had a 1972 gremlin x with a 258, now there's a car that ran great for being stock. Those/6's didn't have a chance against it not from a dead stop or a 30 mph punch.There was a feller I knew that had a Super six in a valiant hed always say how it could lay rubber up and down the street...he tried it once I dont remember it being spectacular but it did do a burnout.
318 Long Block Bolt Ons - Tech Articles - Mopar Muscle Magazine
Something like thatGreat article, like how they broke down the steps of the add ons.
Was wondering about the compression ratio of their Recon 318 long block? Something like 8.2 to 8.5:1 compression ratio?
1 cr point suppose to gain 3-4% hp so like 290 hpGuessing by the looks of the original 318 truck exhaust manifold, that engine probably came out of a 1976 D100 Pickup with the same compression ratios listed above.
Was wondering what the final Results would have been had they started with a 1969 318 9.2:1 230 horsepower stock 2 bbl engine.
High doubt the 318 ever actually made 230 hp, look at the gross 2bbl 189 hp number before cam and 4bbl, not much difference between 318 specs over the years, 230 hp very generous rating.Stock 230 hp, with the addition of the cam, 4 bbl intake and 4 bbl carb an upgrade of 100 horsepower.
330 hp nopeGreat article, like how they broke down the steps of the add ons.
Puts them at:
230 + 100 = 330 horsepower
Hmmm . . . Interesting Thought.
I don't know what class you're talking about,but I looked up what car manufacturers made a 170 CID 6 cylinder engines and I only found 2, one was the mopar 170 and a ford. GM and AMC never offered a 170 cid engine. I'm sure that there was more than 2 manufacturers involved in the event. Do you know what manufacturers were involved in the competitionYou need more experience and less theoretical BS and marketing. There was a 170 cu in limit and I was talking about historical fact, the other manufacturers were not even close. All /6 use the same bore, only the rods and cranks change until the smog era. A 170 has the shortest stroke and a shorter deck, and will rev the best of the /6's. Also being the smallest cu in using the same head will naturally rev higher. The 170 I put together would easily beat a Chevy 235 straight six in anything an engine does for next to no money.
www.forabodiesonly.com
