Anyone know where I can download instructions on how to degree a cam? My comp cam shows the info at .006 on the cam card. My Summit instructs talk about everything at .050. I'm so confused.
I'd bet your measurements might be a hair off. I have yet to have a Comp that was not dead nuts on it's designed installed centerline. I would not advance it, leave it where it is.
lil, Comp grinds thier cams with advance in it. That's whay it's in at 106, yet the camshaft centerline listed is 110. Just my opinion of course.. One can advance the installed centerline, but advancing a cam that is properly chosen, and designed as the XE line is for making cylinder pressure, can put you over the pump gas threshold pretty easy. Also, if he's running a tensioner and/or a good chain, the stretch means virually nothing. It's there of course, but it will not make any difference. 2° is barely measurable/feelable, 6° is huge.
