Camshaft end play, thrust plate questions
MagnumBarracuda
Valders
I'm installing a hydraulic roller Howard cam in my 408. It is a 5.9 magnum block. I understand that the thrust plate is the only thing controlling end play? Does the plug in the rear of the block need to be set somehow? Do i need shims? Or do i simply reassemble? Thanks
Put the cam gear on and measure again. The thrust plate controls forward motion and the cam gear controls the rearward motion. The play in between makes the cam "float" and the crank gear and chain keeps it in the middle so to speak.
