what's in it now?
and how often are you running up to shift-rpm?
If 95% of your driving is below 4000 rpm, why install a 5500/6000rpm cam, jus asking? I mean we all do it to some extent, but why.
If the current combo spins the tires all the way thru first gear, a bigger cam is not gonna benefit your combo in first gear.
If the current gears do not let your engine wind up into the power zone,in second gear, then a bigger cam with no other changes will just be slower.
If the current combo spins the tires, thru two gears already, then what possible advantage would you get from a bigger cam?
If your 60ft is in the 2.4 or slower zone, then you can make up more time here than with more power at 5000rpm which depending on your gears, you might never get to in second gear, below the speed limit.
For example;
3.55s with a 904 and 27s is 4000rpm@ 60mph@ @5% slip. So having 15 hp more at 5000, helps you nothing. Whereas 15 ft pounds at stall could.
IMO, you should be thinking more about maxing out your power,and gears, in the area you spend the most time.
For example, 30 mph.
By 30, if you have worked your chassis up to speed, and got the spinning under control, then,at 30, you want to be on the fat part of the power curve when the trans kicks down into first. But you can't be, there is no combination of gears in the Mopar catalog that can get you there.
So second best is to stall somewhere on the fat part or close to it on the rising side. So if this occurs at 2400, then you want a 2400 stall . But if this occurs at 3000, then 3000; if 3500 then 3500 and so on.
Lets just say your engine, with it's current cam, makes 200ft lbs of torque at 2400, then the simple math is 200x2.45=490 out the trans. but if it makes 240 at 2800, that would be 588 out the trans. And if it makes 280@3200, then 686 out the trans. 686 is 40% greater than 490. You cannot match this increase with one or two cam sizes. In fact, each bigger same type cam , with no other changes, is most likely to subtract bottom end torque to get that topend power.
Your next tool is gears, to put the power at the rpm you need it to be.
Going back to 30 mph, and say a 3200 stall TC, you might want to be at 3200 at that 30 mph, at KD into first.And the math; drumroll, comes to 3.23s. And 3.23s will get you 60=3700 in second gear. So if you have a cam that powerpeaks at 5000 what good is that gonna do you? 3700 is barely on the torque peak. A bigger cam will just slow you down.
So, you need a compromise... or a bigger engine with inherently more midrange power.
The compromise might be 4.30s. Now the rpm at 60 in second gear is 4900@5% slip, and 30 is 4140 in first. Hey that's looking pretty good. But now, you have a different problem; namely way too much Torque Multiplication in first gear at zero mph. So that 3200 is not helping you anymore.
Lets go back and take the engine torque all the way to the road.
With the 2400TC we had 490 out the trans which with 3.23s is 1583 to the road. With the 3200TC it was 686, so with 3.23 would be 2216.
Ok so now, with the 3200TC and 4.30s, this is 686x4.30=2950! easily 800 more than you need. So lets go back to the 2400. So then 490x4.30=2107 just enough to squawk fat street tires, maybe spin them up under the right circumstances.
So we come to another compromise.
Lets go get that 2800. This was 240ftlbsx 2.45 first gear x4.30 rear gear, so 2528 to the road, and there ya go.That will be a tire-fryer.
Ok so far, we are at 4.30s and a 2800TC, for 240ftlbs at 2800 torque.
But we're not done yet.
Firstly; the 240 footpounds I'm talking about, is an arbitrary number I assigned to your engine. You could have more or less depending on your combo.
Secondly; Remember I said, in the beginning, simple math. The TC is More than just a fluid coupling. It is also a Torque Convertor. It has the ability to multiply the engine torque coming into it to a higher value, before it sends it out the back. This TM (Torque Multiplication) is greatest at zero mph, and rapidly diminishes as the vehicle moves forward. I have seen TM numbers as high as 1.8 . Typically, by top-speed, the number may have diminished to 1.1 or less.
So lets stick with the 200/240/280 numbers, but lets install some TC TM.
Beginning with the 2800 which previously stood at 2528ft lbs to the road. Lets add a 1.8 factor at zero mph. And I get an instantaneous 4550 ftlbs to the road, obviously far in excess of what is needed to break the tires loose. But like said, this ratio rapidly diminishes. By 60 ft out, it might be down to 1.3, IDK. But at 60 ft out, your tires are still smoking so it really doesn't matter what it is.
Furthermore, with 4.30s, your no-spin rpm at 30 mph is easily 4100 or more, so by this time, you don't care about stall.
Furthermore, kicking down into 1.45 second to pass a car at say 58mph, the rpm might rise to 4700, so again, stall is irrelevant.......... That means, the only time stall is relevant, is at zero mph, and as we have seen 4550 is crazy, so lets put the 2400 back in,lol. This TC was 200 crank x2.45 x4.30 x1.8=3790 at zero mph, still far in excess of what you need to launch with.
To recap; now we are at 200ftlbs at 2400, a 2400Tc, and 4.30s At 30 mph KD, the rpm will rise to 4100 and you are G-O-N-E, in all likelihood smoking the tires at WOT.
Ok, so what is 200 ftlbs at 2400. Well criminy a smoggerteen can do that.
So, remind me, what was the purpose of the 4.30s again? That's right, to maximize power at 60 mph, to minimize the time to get there. If you don't care if yur car is a lil slower, then run less gear. But when you do, make sure your stall is high enough at the other end, to still get outta the gate in a manner that keeps you smiling.
Each bigger same type cam (~7*) will raise your power peak up about 200 rpm,at the expense of wanting nearly the same more stall, all other things remaining equal. A lot of the midrange is gonna be similar.
You can increase low-rpm torque, by trapping more mixture, or compressing it to a higher psi. In this way you can get back some or all the low-rpm torque, that the next bigger cam gives away. This only works in a narrow window, as too much pressure can rapidly drive the engine into detonation on pumpgas. Cranking cylinder Pressure at WOT, is a better measure of when to quit than Static compression ratio. Each bigger size cam ,with no other changes, will reduce you cranking pressure.
As to pressure, here is a guideline
105 is a pure dog no matter how many cubes you have.
115 still doggy, I've seen lawnmowers with more pressure.
135 is typical of a smoggerteen.And you probably know what that feels like.
145 is like a 360LA, or an early 318
155 is like an early 340,which could be up to maybe 165
165 is about the max you can run on pumpgass (R+M)/2,and iron heads, with an optimized chamber.YellowRose and at least one other member, are saying 170 can be done, but you better have your ducks all in a row.
175 is alloys only, generally.
185 is getting to the top of alloys, but some designs are still on 87E10.
195 is about the max for alloys on best gas.
These are numbers mostly accumulated from real world engines right here on FABO.
I'm going to have to read this all again...its a lot of information...
1 step at a time and my car will one day be without want/need more more parts.
