I live here; over 9000posts, in 27 months,lol
My little 367 has 3.55s and a 3.09 low, and 27" tires. This computes to a starter gear of 9.75 corrected to a 24 inch tire.
Your NP435 might have ratios of 4.56-2.28-1.31-1.00
You have 3.55s, and 33" tires, right so far?
Well, your granny gear computes to an 11.77 starter gear corrected to 24" tire.
That means you have 11.77/9.75=1.2072 or Plus 20.7% more torque multiplication than I do.
Now My combo will smoke 325/50-15 Drs all the way thru first gear and beyond.These are 27 tall and about 10" of rubber on the road
The footprint or contact patch of your 33s, might be a little bigger than on my DRs, so perhaps they will stick a bit better.
But the clincher is you have a 440, with 440/367=1.199, or plus 20% more cubes.
What I'm thinking is you could have a totally screwed up combo, and still smoke the tires all the way thru first. And that is what you wanted right?
You have 20% more engine, and 20.7% more gear, with prehaps a tiny bit bigger patch.
You are at 6000#. I am at 3600# This is no big deal on the street. If anything it will help you, cuz the truck will not accelerate as quickly, so IMO it may spin longer. You don't care about fast, just spinning tires. I am confident that, that first little 220ish cam would have got the job done,allbeit without the raunchy idle. So IMO whatever cam you get, it too will get the job done.
The problem I see is when it hits second gear. This is a 2.28/4.56= 50% split. In other words, whatever rpm you rev first out to, the revs will fall to 50%.
The synchronizers in that tranny were never designed to work at 6000rpm. Nor to be Bang!-shifted. They were probably designed for 3600 to 4000 max. I don't know how they will fare at near 6000, or how long they will keep working.
So, if you carry first to 5000, the Rs will drop to 2500. And at 6000 pounds of chassis, you are done.This will be about 30mph. I hope you are good with that.
I another thing I don't know is how long that unsynchronized granny gear is gonna take that BB torque. It was never designed for this kind of abuse.IIRC this gear is about 7 or 8 inches in diameter, while the cluster gear is maybe 2 or a 2.5.
I suggest figuring out a way to get moving without excessive rpm clutch drops.At least until you figure out she can take it. Maybe get a line-loc.
I'm looking forward to see how this works out.
