I was told that since these cranks share the same rod and main journal size and stroke, a 273 forged crank can be balanced to fit a 340.
I have never tried this.
I have a friend that had a 340 built at a shop and the engine developed a spun rod bearing at less than 100 miles. I helped with the teardown, it has a severely grooved crank. I told him that I have a 273 crank he can use BUT I need to know if it can even work.
The forged 340 cranks seem to have that drilled section on the 1/2 and 7/8 rod journals. Can a 273 crank me modified like that to work? If not, what else needs to be done?
