Howdy all, cosgig here! I'm trying to identify this distributor that came on a running small block motor I bought! There are no markings anywhere on the unit except for a date stamp of Dec. 2012! I tried to take the steel cover off that covers the brain, but it wouldn't just lift off and I didn't want to pry at it just yet! It was running in the circuit with a Blaster 2 coil, the 2 wires running from the distributor to the coil, and 2 jumper wires spliced into the ballast harness, one from the coil to the harness, and one from the other side of the ballast to the main underhood harness!!
Sooo, here's a couple pics of the distributor, and a pic of it actually hooked up and running! Any help would be much appreciated, I would like to use this in my Cuda if I can, but want to be able to service it if needed!! Thanks for any and all replies!! Geof
