I cant seem to resolve my hot start issue and tired of buying stuff. I know there are a lot of particulars; Im just trying to be thorough. 72 Dart 318, bore 30 over, stock heads, flat top eyebrow pistons, Comp XE256, New Eddy Performer Intake and New 1406 Carb. Engine was rebuilt 800 miles ago.
Here is what I have done. New water pump and radiator. Ignition Pertronix II and Flamethrower II coil, distributor is new and locked at 20 mechanical. Idle is at 14 btdc, 34 deg at wot and vacuum is at 20. Engine is set to idle at 700 rpm in park. I have new mechanical fuel pump, pressure is regulated at 5lbs, new fuel filter. New Autolite 66. The carb has been cleaned and float, idle mixture adjusted, needle and seat clean and working. Also new Eddy Heat spacer 9266. I have also insulated the fuel line from the pump to the carb. Engine temp gauge is always below half and never dies or gets hot.
I am confident that the carb is getting hot and either boiling fuel or flooding. The bowls are not empty. If I pump the throttle it gets worst. If I hold the key for 5-7 seconds it will start. If I hold the throttle to the floor it starts quicker. The engine starts quick when cold and every time hot but, just takes 5-7 seconds.
Is this normal and do I have to accept this? Can this be fixed or what else can I do? Thicker spacer, Holley, electric fan. Im all out of ideas. Im hoping somebody can fix this. Thanks
