Can I get away with using a single spring kit with this cam?
myasylum
Las Vegas, NV
Lunati of course suggest there springs, but them the heads have to be cut to use them. Can I get away with a single spring, can someone suggest one?
Thanks!
Brand
LunatiManufacturer's Part Number
60403LKPart Type
Camshaft and Lifter KitsProduct Line
Lunati Voodoo Cam and Lifter KitsSummit Racing Part Number
LUN-60403LKCam Style
Hydraulic flat tappetBasic Operating RPM Range
1,800-6,200Intake Duration at 050 inch Lift
226Exhaust Duration at 050 inch Lift
234Duration at 050 inch Lift
226 int./234 exh.Advertised Intake Duration
268Advertised Exhaust Duration
276Advertised Duration
268 int./276 exh.Intake Valve Lift with Factory Rocker Arm Ratio
0.494 in.Exhaust Valve Lift with Factory Rocker Arm Ratio
0.513 in.Valve Lift with Factory Rocker Arm Ratio
0.494 int./0.513 exh. liftLobe Separation (degrees)
110Intake Valve Lash
0.000 in.Exhaust Valve Lash
0.000 in.Computer-Controlled Compatible
NoLifters Included
YesLifter Style
No
No
No
No
No
No
No
No
Sold as a kit.
Depends on what the single spring rate is.
Yes, they recommend there double springs. I was hoping to get away with a single spring so I wouldn't have to modify the heads.
Let me look into that. This is what is suggested...
Brand Lunati
Manufacturer's Part Number 73949
Part Type Valve Springs
Product Line Lunati Intro Series Valve Springs
Summit Racing Part Number LUN-73949
Number of Springs Per Valve Dual
Outside Diameter of Outer Spring (in) 1.440 in.
Coil Bind Height (in) 0.950 in.
Damper Spring Included Yes
Spring Rate (lbs/in) 363 lbs./in.
Inside Diameter of Outer Spring (in) 1.070 in.
Inside Diameter of Inner Spring (in) 0.745 in.
Valve Spring Style Standard
Coated No
Quantity Sold as a set of 16.
I will say no. There are single springs availible with similiar specs but they may be using duals to reduce some kind of harmonic.
Here are the specs for the recommended springs for you application.
Intro Series™ - dual w/damper 1.440 120@1.650 265@1.250
Product Description
Lunati Intro Series valve springs are manufactured using the finest chrome silicon valve spring wire and manufacturing processes available. These springs were designed for use in your hot street machine or Saturday night bracket car.Lunati Intro Series™ valve spring set
* Spring Type: Dual w/damper
* Outside Diameter: 1.440 in.
* Inside Diameter: 0.750 in.
* Seat Load: 120 lbs @ 1.650 in.
* Open Load: 265 lbs @ 1.250 in.
* Coil Bind: 0.950 in.
* Spring Rate: 363 lbs/in.
Part Number: 73949
Jobber Price: $139.43
You can try a similiar single spring, but you may just have to pull the heads off again and do it right the second time.
Yea, I called the shop that has my engine. They said that they have a beehive "type" spring they'd like to "try". The problem is if it don't work, as said above... It will have to be taken back apart, and guess who has to pay! I guess, I'd be paying for the machine work anyway.
