i really hope you mean at least .005 or .050, not half an inch
He's talking about the .500" down cylinder fill. That's the correct way to measure piston head volume.
No, I meant .5. According to Sheppards book, you drop the piston down .5" and then fill the chamber and subtract the difference from 99.9 cc to get the dome volume
I admit I did speed read thru this thread, but that engine seems to be a rare build these days. As long as the cylinders are clean enough with a light hone, i'd keep it as is. What I mean is, with a good clean up, it would make a real nice bracket engine with a little more cam. I'd probably put it under the bench for now, or see if someone else wanted to use it for how it was built, and maybe find another engine for your needs/want's on the street.
If I went to E85, will it eat out the gas tank? I already have fairly new carb so that should be OK.
