Dezduster
My reply to the question why do strokers cost so much.
So you pick out a stroker kit 1300 for a cast crank, cast piston and a forged rod kit with a balance job. I chose Scat, they as a company have been around for a long time and are trusted by many.
1300-2500
So now on to the block prep mag for cylinder thickness, bore, hone, well this is going to be a special engine to you and they are. So correct and square the deck clearance for rod bolts, radius all edges and clean up casting flash, cam bearings. Hard block?
400-1000
Main studs or main bolts but certainly not stock.
100-150
Heads rebuild, BUT the stock heads are nothing to write home about in stock form, so do you have them ported and rebuilt with quality componenents or buy new heads?
700-1500
Well you can buy heads that have flow numbers already known, they are NEW CASTINGS and this engine is special. Could have these ported as well.
1200-3500
Head bolts or studs.
120-200
Ahh the heart of your mill the mighty cam this engine is special!
Flat tappet cam break in sucks so I went roller BUT whose roller stuff is better than you need but doesn't break the bank?
I went with Hughes cam,lifters, rockers and pushrods.
700-2000
Timing chain
60-150
So this covers all the big components but how much is in the smaller less expensive components?
Intake heads were ported so intake also?
200-600
Balancer
150-400
Finally have a long block minus tin.
You could use some of your old stuff but this is a stroker and some doesn't work. So new pan with windage tray for stroker.
200-400
Valve covers
80-200
Ignition
150-1000
Carburetor or EFI
400-1000
1500-4000
So really it's the snow ball effect.
It can be done for cheaper than what is listed above but it will have sacrifices to performance, durability, longevity and visual appeal.
As a street car guy 4x4 enthusiast the cost us worth it. The torque and drivability is far more enjoyable than a camed up stock some high compression engine. But to each their own.
1300-2500
400-1000
100-150
700-1500
1200-3500
120-200
700-2000
Timing chain
60-150
200-600
Balancer
150-400
200-400
Valve covers
80-200
Ignition
150-1000
Carburetor or EFI
400-1000
1500-4000
