Can you change vent and filler tube
I installed the 1969 filler neck with vent today. I also installed the 1968-1970 18-gallon gas tank, and it was a real pain to get it all aligned and fitting to seal correctly in the trunk floor seal. I installed the filler tube and the seal on floor first then put the tank in. That was the easiest way to get everything to line up and fit. Also, I looked at my old trunk floor seal and if you look the seal pushes into the floor this is how it seals, I was thinking the seal flange stuck out into the trunk area and it wouldn't make the angle to seal the filler tube It took a little trial and error, but it all worked out and all fit. I used a 1970 fuel cap which fit perfectly with the 1969 fuel filler tube being mounted from the inside.
Mine was around $60. with a vent tube, that had to be slightly rebent. That's for a '69 Dart. They can get up to $80. depending on your application.
Sweet!
How much did the new tube cost and did it come with the vent tube?
I got it on eBay for $45 and it came with the tube but tube needed tweaked. I may make a new one out of 1/4” brake line or see if I come across a good used one. The one I tweaked isn’t horrible because it’s behind the tube and you don’t see it. I also used a new repopped 1970 gas cap which easy to find.
