Canadian Eh
CDN68
Member
Calgary Alberta
Hello All and thanks For the add.
Here is my 68 with a magnum 5.9L solid roller 727 a gear vendor and 3.55s #UU1 Frost Blue
Welcome! Tell us about the Dart! What’s the history on it?
I bought her 3 years ago . From a guy in Cold lake Alberta . He bought the car out of BC. Originally a 273 Colum shift car with a bench seat . Has been converted to the proper tear drop floor console. The motor that was in it when i bought is was a 1967 date code steel crank 318 (still have short block assy ) with full floating pistons . Starting from the rear the open gear 2.76s came out and she got a set of 3.55 with a clutch style posi. Axles are from Diff Doc 5X4.5 Bolt pattern and 11X2 rear shoes . Trans is stage 2 shift kit 727 the torque convetor is TCS 10" 3000 stall Current power plant is a Magnum 5.9L with a lunati solid roller 237 @.050 intake and 243@.050 exhaust using cheby 1.5 rockers .566 lift intake .578 exhaust heads have been bowl blended and have 2.02 intakes and 1.60 exhaust . With a magnum M1 intake and a Quick fuel 750 double pumper . Oh and of course SS Springs . If i forgot something please feel free to ask :) pss LOL i did forget something she also has a gearvendor
